Need Help! Amada Fanuc PEGA 357 no booting
Results 1 to 17 of 17
Thread: Amada Fanuc PEGA 357 no booting
    Member Neozebulon's Avatar
    Sep 2021
    Default Amada Fanuc PEGA 357 no booting
    Hi ,
    I've got a problem with Amada pega 357 punch turett,
    Error e05 s-memory(low) parity error
    I phone Amada and say me motherboard was died and 3 other cards for a total of 30000$ .
    It's too much for my society.
    Can you help me ?
    Attached Thumbnails Attached Thumbnails Amada Fanuc PEGA 357 no booting-1631525624074-jpg
    Apr 2009
    Default Re: Amada Fanuc PEGA 357 no booting
    Give more info on the control please: photos help.
    Sep 2021
    Hello ,
    It's fanuc O4PC
    If that help you for find my problem.
    The boot screen is freeze with the error E05 , but i can do origin axis .
    The machine is connect to old pc win95 on a box named "adr inc"
    Attached Thumbnails Attached Thumbnails Amada Fanuc PEGA 357 no booting-1-jpg   Amada Fanuc PEGA 357 no booting-2-jpg   Amada Fanuc PEGA 357 no booting-3-jpg   Amada Fanuc PEGA 357 no booting-4-jpg
    Amada Fanuc PEGA 357 no booting-5-jpg
    Apr 2009
    Thanks. Although that control is essentially a Fanuc 0-C control, I am not familiar with the "Error e05 s-memory(low) parity error" that type of an alarm has always been a 'fatal' one: no machine operation could be done until the alarm was cleared.
    Do you have a recent backup of the programs, parameters and diagnostics?
    I was thinking 10/11/12 or 15A with the connection unit there. Some form of very early MMC or Front end interface hybrid.
    Dec 2015
    Try to replace memory board only & after press+ cancel+ del button or del+rest. Hope you successfully boot O-C controller. My guess have any track is missed in memory board.
    quick-cnc
  7. #7
    Sep 2021
    Quote Originally Posted by memoryman View Post
    Hello i've got this program (in attachement), but i 'don't kown if are just maccro or pms parameter and maccro , it's chineese language for me
    Today i have deleted memory , RESET + DELETE button at boot , the error is always here
    I show you all the cards that Amada wants to sell to try to fix my machine.
    How can i replace memory ? i dont 't know where it 'is.
    Thanks for help me
    Attached Thumbnails Attached Thumbnails Amada Fanuc PEGA 357 no booting-devis-carte-pega-jpg
    Attached Files Attached Files
  8. #8
    Apr 2009
    The memory chips are soldered and also socketed on the MEM BOARD, (A16B-1212-0210) There are also various other chips on that board involved in the memory area; it's likely that the problem is on that board.
    What country and city are you in?
  9. #9
    Sep 2021
    If i remove the memory card (A16B-1212-0210) , i loose all machine parameters ? (PMC) ?
    I am in France in "le Mans"
  10. #10
    Apr 2009
    The backup battery is connected to the mem.board; you have 'some' time (hours?) before losing the data after unplugging the battery. (there is capacitor on the mem.board for that). The parity alarm means that you lost the data anyway.
  11. #11
    Sep 2021
    OK, I will see to have the memory card checked,
    For the machine parameters, I found some old numbered paper tape, I think it's the parameters but I have no idea how to use the tape reader.
  12. #12
    Sep 2021
    Hello ,
    Always with my problem on my Fanuc 04C
    I unplug the memorycard , clean and check it , i see nothing.
    But when i plug it , i have a new screen error at boot.
    I think the eprom slot 3 is died ? it's good ?
    Where i can find the microprogram 0156 FC1C if my diagnostic it's correct.
    Attached Thumbnails Attached Thumbnails Amada Fanuc PEGA 357 no booting-1634739302728-jpg   Amada Fanuc PEGA 357 no booting-1634739302739-jpg
  13. #13
    Apr 2009
    You have lost all volatile data: parameters, programs, diagnostics etc.
    Turn the control ON while holding RESET and DELETE buttons;the reload parameters and diagnostics.
  14. #14
    Sep 2021
    Already done but I cannot start the machine without the error screen.
  15. #15
    Dec 2015
    Quote Originally Posted by Neozebulon View Post
    Please share the picture of full Masterboad.
    quick-cnc
  16. #16
    Apr 2006
    Viet Nam
    Master board error
  17. #17
    Sep 2021
    Quote Originally Posted by phucrobusl View Post
    Masterboard
    Attached Thumbnails Attached Thumbnails Amada Fanuc PEGA 357 no booting-s-l1600-jpg   Amada Fanuc PEGA 357 no booting-img_20211110_113709-jpg
  18. #18
    Member maotran's Avatar
    Nov 2019
    Can you help me, boot (make backup) againt Parameter, PMC, DNC,.. for Pega 244 O4PC.
    Thanks so much.
  19. #19
    sure
