PMC programmer needed for 21i-t
Results 1 to 3 of 3
Thread: PMC programmer needed for 21i-t
    Dec 2011
    Usa
    Default PMC programmer needed for 21i-t
    I have a lathe with a 21i-t.
    I need several things added/changed in the pmc program.
    I am more than happy to pay something reasonable for someone to make some changes.
    I can send you the program.
    Here’s what I need;
    Be able to pause program, jog axis, then restart program where it was paused at.
    F1 key to switch spindle between run and jog. (Spindle start button just jogs it now)
    F2 run spindle at 100 rpm
    F3 select external jog wheel
    Setup info/programming for external mpg with axis selector and step selection. This is for a hand held mpg.
    Default Re: PMC programmer needed for 21i-t
    A note on the remote: Not sure the size of your facility but I suggest ensuring the remote MPG unit you purchase has an E-stop button as well as a 3 position enable button.
    A pain I know but required for those that try.
    Dec 2011
    Usa
    Quote Originally Posted by oetkbyentc View Post
    Thanks for info. I’m just a one man show.
