"Turret not clamped" Error
Results 1 to 8 of 8
Thread: "Turret not clamped" Error
    Jun 2017
    India
    Default "Turret not clamped" Error
    Hello,
    I have a CNC whose control is Fanuc oi mate TD. From last few days we are getting Error "EX1005 Turret not clamped". Engineer came and he replaced Proximity sensor, Encoder. And he also changed inside parts of the Turret. Still we are getting same error.
    We are very fatigued from last 15 days due to this Error.
    I found this Forum is group of Real Experts. Please help me.
    Regards,
    Dec 2009
    ROMANIA
    Default Re: "Turret not clamped" Error
    try to change the relay for the clamp/unclamp .it is acting the hydraulic electrovalve
    Control series?
    Can you determine if the turret is actually clamped while the alarm is displayed?
    If the turret is clamped but the alarm is still issued you need to look in the ladder.
    If the turret is not clamped check the relay as previously suggested.
    Ladder;
    Look at the PMC status bits. Search "A0". Start scrolling through that area. When you find a address that is 1 search that address in the ladder. If it is not the alarm you are seeing repeat.
    Once you find the alarm for the clamping; Determine what is logically keeping the alarm displayed. Some PMC programmers require a reset procedure rather than just a simple reset to try to ensure a specific sequence was met.
    Jun 2017
    India
    Thanks all.
    Problem is resolved by Replacing Encoder and Proximity Sensor.
    But this error is displaying one time per day(Same job repeats 350 time per day). Any reason why its showing even for 1 time ?
    Regards,
    Jun 2017
    India
    Now this Error is again Prompting. I switch off my machine at night correctly without error. But whenever i turn on my machine on next morning. Its shows "Turret Not Clamped" error !!
    After 20 minutes, machine start working correctly and it never shows till night.
    But today morning, this error prompting when i turn on my machine. But its not going away after 20-25 minutes !!
    Please HELP me.
    Regards,
    Based loosely on your description of how the alarm progressed my first guess would be a loose connection that has finally failed completely.
  7. #7
    Jun 2017
    India
    Today Engineer visited my workshop. He found there is mechanical issue inside the Turret. He changed 2 Bearing. Now its working fine.
    I wish it will be Permanent solution.
  8. #8
    Member cncmakers001's Avatar
    Jul 2011
    China
    Quote Originally Posted by dolarpond View Post
    So the Encoder and Proximity Sensor should be fine, this is mechanical problem.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
