21i-t tool change position
Results 1 to 5 of 5
Thread: 21i-t tool change position
    Dec 2011
    Usa
    Default 21i-t tool change position
    New to fanuc controllers. I have a Romi G30 with the Fanuc 21i-T.
    How do I change the turret position when it does a tool change?
    It wants to go to a spot it crashes tools into part and/or chuck.
    Apr 2011
    Default Re: 21i-t tool change position
    Parameter 1241. This is tied to G30 U0 (X0) and W0 (Z0). This value will be in MM so be careful if you are programming in inch. Input the value where you want the axes to go from MACHINE zero.
    Dec 2011
    Usa
    Quote Originally Posted by drdos View Post
    I will try it tomorrow.
    Thank you for info.
    Dec 2011
    Usa
    Tried 1240 and 1241
    Not it.
    It wants to do tool change at part x0 z0
    Dec 2011
    Usa
    I did find a work around, or for all I know it may be just the way to do it.
    In the Process you need to select the detail screen. The Approach values is where the tool will change at.
