PWE parameter is 8000 set all to 1 for entry of 9000 para.
Macro B for a T is xxxx bit 0 probabally the same for 10M
Fanuc Bulletin attached.
We have a couple of mid 80's Mori MV55's with a Fanuc 10M and 11M controllers that I have a couple of questions about. The newer machines have vast amounts of information available but I cannot find any for these dinosaurs.
#1 How do you lock and unlock 9000 series programs? I know how on our newer controls with parameter 3202.
#2 Is it possible for these controllers to read variables? I've been told they cannot.
#3 The programmable data entry does not work. I get an alarm when the machine reads the G11 code to cancel programmable data entry.
#4 The machines will helical interpolate but will not interpolate a counterbore if there is an offset other than 0 in the radius offsets. I have to use 4 quadrants to interpolate, it throws an out of radius comp alarm if I try to use a single line interpolation. How do you fix this?
#5 How do you turn on extended work locations? One of them only has G54 thru G59.
Thanks for the help,
Jason
I'm not sure what "Macro B for a T is xxxx bit 0 probabally the same for 10M" means but the 8000 parameter is locked. I get the write protected message when I try to change it.
Parameter 2201 bit 0
Got parameter 8000 unlocked.
Thanks cncdiag for the 9000 program unlock, that's one off the list.
Here's an update:
One machine will read variables and the other will not. The one that will I've been told is a 10M control and the other is a 11M. The 10M is a newer machine (1985) than the 11M (1984), and has the extended work offsets turned on.
You cannot change parameters with programmable data entry (invalid G code alam with G11) on either machine but if I can get the 11M to read varialbes then this is not an issue.
I know I need to find a parameter manual.
Thanks,
Jason
To change option parameters you have to load them in hex.
Power up the control holding in the "-" and "." pushbuttons.
This will bring up the IPL page
Press 9 twice then input.
This will bring up the option parameters.
Press input until you get to the option you want to change.
Enter the hex value then press input.
Press input until you get to the end.
Press 6 input
Re the Loading 9000 parameters on 10 11, this is a copy faxed to me by GE-Fanuc US, when I had to get a option for a customer.
I have spoken to Fanuc since, and they say it is not possible to do it by PC??
Interesting to see Fanuc 15 listed at the top of your sheet from fanuc, I have always assumed for a 15, you had to input the three code numbers before being able to set options.
Also, I have always had to set the option parameters by hand, 10,11 & 15 controls, as when uploading the parameter disk they are always ignored as "Locked Parameters" whilst my laptop is outputting the "9000" parameters previously dumped out from the control to disk e.g. 9000 parmeters are punched out, with the others, but ignored when read back in. If someone knows another way, please let me know, as manual input of option parameters is a pain in the brain, as setting one wrongly can have major repercussions.
Another point worth mentioning, if you only want to change one 9000 parameter, the parameter number is equal to the option number plus 1. If you wanted to change parameter 9110 for instance, this is option number 11 on the list.
On my list, to be able to write, punch or edit 8000 programs, bit 11-0 to a "0", for 9000 programs, 2201-0 to a "0"
dear all,
is there anybody who will help me providing me the service manual of cnc bore milling SCHARMANN-FB 100 and also of FANUC series 10-M. Actually im facing a problem thet the B axis and the Spindle is not working...it's hard for me to dignose the the problem without the maintenance or service manual..plz help me
thank you
kind regards
shekhar
india
dear sir,
in fanuc-0m control macro programe is not working.please give me a suggesion .
i have takisawa mac-v2e with fanuc 10m
need help on setting corrrect data in counter c01 c04 etc
if tool 1 is in pocket then whatshould should the data be , i have 24 tool changer.
preset ? in pocket ?
thankyou john
You can load All parameters into a Fanuc control by RS232
Need:
to set all parameters that Lock anything to thier unlock state
to make sure when reloading them the baud rate and such match
what your useing to load and what is set in the parameter file
Now VAIL101
Counters and Data tables are "Machine" specific not Fanuc controled.
We need to know what machine this Fanuc is on then maybe we can help
Some times the counters are an equal value for the carousel 1=1 2=2 but
sometimes the spindle is 1 and the carousel is +1 on every pocket
In the first case the spindle would be counter 25
