Software "Fanuc Memory Card Transfer Tool"
Results 1 to 6 of 6
Thread: Software "Fanuc Memory Card Transfer Tool"
    Member decara's Avatar
    Dec 2018
    vbjkk
    Default Software "Fanuc Memory Card Transfer Tool"
    Need your help..master
    I need software
    " Fanuc Memory Card Transfer Tool "
    abdibtm@gmail.com
    Attached Thumbnails Attached Thumbnails Software "Fanuc Memory Card Transfer Tool"-screenshot_20210730-225700_youtube-jpg
    Dec 2012
    The Netherlands
    Default Re: Software "Fanuc Memory Card Transfer Tool"
    Fanuc Program Transfer Tool - A08B-9510-J515 ( v15.0 ) costs in Europe approx. €20,- / €25,- ( $24,- / $30,- ).
    Fanuc Memory Card Program Edit Tool ( v5 ) - Fanuc A08B-9010-J700/ZZ11 costs in Europe also approx. €20,- / €25,- ( $24,- / $30,- )
    The Card Tool needs at least a Fanuc 0i-D or 30i-32i and runs standard on a Fanuc 0i-F.
    If you have a 0i-MD/TD you need; A02B-0319-R642 ( 0i-TD - Lathe ) or A02B-0320-R642 ( 0i-MD - Mill ) to run these BIN-files on Card.
    When your control has the [ MEM-CARD ] and [ MEMORY-CARD ] soft-keys then you can run the Card Tool (BIN-Files).
    Fanuc Europe has two videos on their YouTube-channel how to run both programs, the v15. version of the Transfer Tool can handle the Card Tool BIN-files aswell.
    Dec 2018
    vbjkk
    So fanuc 18i mb...cannot?
    Dec 2012
    The Netherlands
    As for as I know not on a 18i - series, you will need at least a 0i-D series with A02B-xxxx-R642.
    For the Program Transfer Tool, probably it will work with a correct Ethernet connection.
    Dec 2018
    vbjkk
    Master, so now . Fanuc 18i mb
    How to upload/download PC to CF card(NC)?
    Please need your idea
    Dec 2012
    The Netherlands
    There still options to use CF card for large programs by DNC or M198 via CF Card.
    There are lots of videos on YouTube that shows you how to do it.
