Hi I got a Ikegai FX25Z with a 6T control
We bought the machine new back in the eighties with no problems all the years.
Everything works in Manual mode but when i switch to automatic the Machine will not move after it indexes to the correct turret position in automatic..It will only move the amount that is in the X and Z offset.
After i hit the reset button the machine will execute the rest of the program. After i hit the start button again the same thing will happens again. It will index and stop again after moving only the offset amount.
Tha machine runs fine thru the whole program if in dry run..
Please can you help me.
Klaus REh
