Need Help! Mori Seiki MV40 with Fanuc 10M control tapping problem
Results 1 to 2 of 2
Thread: Mori Seiki MV40 with Fanuc 10M control tapping problem
    Member onemanarmy920917's Avatar
    Jun 2021
    Default Mori Seiki MV40 with Fanuc 10M control tapping problem
    Hi guys, i have a problem with performing a tapping cycle on Mori Seiki MV40. The machine does not want to perform rigid tapping. When I write M29 on the same line with G84 it does not execute the cycle. However, when I delete M29, the machine performs the tapping, but there is some mismatch of the pitch and the spindel revolutions. Has anyone had the same problem on Fanuc 10M. p.s. It also doesn't want to run G95 mode, which is pretty weird for Fanuc.
    Dec 2012
    The Netherlands
    Default Re: Mori Seiki MV40 with Fanuc 10M control tapping problem
    Hey,
    Try one of these sub-programs, be careful ... it's written in Metric !!!!
    Rigid Tapping with G94:
    O1010( TAP - M5 X 0.8 )
    G00 G80 G90 X50. Y0. Z50.
    G94(MM/MIN)
    M29 S1000
    G84 R3. Z-15. F800. >>> ( F = Speed x Pitch ).
    X0. Y50.
    X-50. Y0.
    X0. Y-50.
    G00 G80 G90 Z50.
    M99
    Rigid Tapping with G95:
    G95(MM/REV)
    M29 S1000
    G84 R3. Z-15. F0.8
    X0. Y50.
    X-50. Y0
    X0. Y-50.
    G00 G80 G90 Z50.
    G94(MM/MIN)
    M99
