Tool Change position as in G30 ? Fanuc should be open to adjust that but the machine builder may have locked the control some way
Hello, does anybody knows the service password to a FAMUP MCL120 machine with fanuc 18i?
I have to adjust the Z position to tool change and on the tool change menu asks for an password.
Tanks
The builder of the machine made an coustum menu with some hidden macro and blocked with service password.
There Menu can do what ever it wants but if its for a Fanuc control for an ATC it will be coming from 2nd Ref position and thats an easy found parameter on the Fanuc side ?------------When commanded in the program does it go -----Goo G30 Z0.or G30 xo yo ?----------If so there program has to use the numbers from the Fanuc side for 2nd ref -------Parameter 1241 should give you the numbers to see if this is were they are coming from
how about G10 L50 N1241 or 1850 P3 R xxxx.xx to re-write the value? Check the Fanuc 18i operators manual.
Usually Axis Values can only be read from like the G30 and First Ref and stuff but it good thinking and alot of parameters can be written to that way
