SV006 alarm
Results 1 to 6 of 6
Thread: SV006 alarm
    Apr 2003
    Default SV006 alarm
    Good Day
    I have a Wasino LJ63 M lathe that I am running off a phase converter.
    when I am Running a program and the machine rapids from the last line to G54 before it starts next line of code I get a Alarm SV006 velocity power to low.
    Is it possible to change parameters to lower the ramp up,or do I do have to change drive board .
    I have 234 volts going into machine on two legs and wild leg is 237v
    I also have 60 amps going to converter.
    Anybody got any solutions
    Thanks in Advance
    Edit / DeleteEdit Post Quick reply to this messageReply Reply With QuoteReply With Quote Multi-Quote This Message
    Apr 2011
    Default Re: SV006 alarm
    Control type?
    Apr 2003
    Fanuc 10 T
    Nov 2007
    Canada and Nothern ireland
    Dont go into G00 for the line just leave it in a fast feed rate for now under a G01 ------Must be an issue with accel and decel that has had the same parameters for a long time so maybe some type of wear or lack of oil causing higher voltage/amps requirement ?------Should get you running fingers crossed-------just make sure well clear of all work piece
    Apr 2011
    Parameter 1620 is the Time Constant (Acceleration/Deceleration) for rapid traverse. This parameter is set in milliseconds. The larger the value the longer it takes to get up to speed.
    Apr 2003
    thanks i will try that
SV006 alarm
SV006 alarm
