Need Help! Compatible encoders?
Results 1 to 10 of 10
Thread: Compatible encoders?
    Member TimmiTball's Avatar
    Apr 2021
    Default Compatible encoders?
    Hello! I have a bad encoder for a Fanuc 10T AC servo drive. The glass encoder disk is actually scratched and the print is worn off from rubbing on the photocells. It is a Type A860-0345-T001. I'm having a lot of trouble finding one anywhere. My question is; are there any compatible encoders that have the same disk/internals that I could look for to use for an organ donor? Thanks!
    Dec 2003
    Default Re: Compatible encoders?
    The problem with a sub for a Fanuc AC motor encoder is the encoder also has the commutation track on it which are a proprietary method that Fanuc uses.
    Where are you located, I may have one, would have to check.
    Apr 2021
    I'm located in southeast PA
    Apr 2021
    Hey Al, did you happen to get a chance to see if you had the encoder?
    Dec 2003
    No sorry I meant to get back, I don't have that model.
    Apr 2021
    Quote Originally Posted by Al_The_Man View Post
    Appreciate it, Thanks anyway!
  7. #7
    Apr 2006
    Viet Nam
    Quote Originally Posted by TimmiTball View Post
    Can you take picture of motor and encoder?
  8. #8
    Apr 2021
    Quote Originally Posted by tuanpq View Post
    The sticker on the motor is worn away, so I can't get a picture of the part number. But I know it's a 10T/2000 with brake. Here is a picture of the encoder though. And the disk where it is rubbed off.
    Attached Thumbnails Attached Thumbnails Compatible encoders?-encoderdrake-jpg   Compatible encoders?-encoder1-jpg
  9. #9
    Apr 2006
    Viet Nam
    What kind of machine. Your encoder is high speed and high resolution encoder. This encoder is rare.
  10. #10
    Apr 2006
    Viet Nam
    You must buy same encoder because your motor have hollow shaft. Screw move through motor.
