Fanuc oi-TD not booting only on light show. Really need help - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Fanuc oi-TD not booting only on light show. Really need help
  1. #21
    Member johnyto25's Avatar
    Apr 2021
    Quote Originally Posted by lshingleton View Post
    Did you repair that encoder or rewire it already ?
    In the Electrical panel when you power on is there any alarms on the board or drives yous can see ?
    No I don't repair the encoder but just remove the plug and then place it back. Nothing has been done to the encoder.
    In the electrical panel when power on there's no alarm. Please check the attached picture, first one for the electrical panel and the second one for the screen and control panel (back of the screen)
    Attached Thumbnails Attached Thumbnails Fanuc oi-TD not booting only on light show. Really need help-img_20210503_094912-jpg   Fanuc oi-TD not booting only on light show. Really need help-img_20210503_094755-jpg
  2. #22
    Apr 2021
    Quote Originally Posted by johnyto25 View Post
    And this how it's when you push the on bottom. You have nothing on the screen.
    Attached Thumbnails Attached Thumbnails Fanuc oi-TD not booting only on light show. Really need help-img_20210503_115701-jpg
  3. #23
    Nov 2007
    Canada and Nothern ireland
    Default Re: Fanuc oi-TD not booting only on light show. Really need help
    The Panel meaning HDMI or VDU has no power at all ?-------If you open that panel can you check connections and also in the main panel for the Fanuc and see if you took out any fuses >?
  4. #24
    Apr 2021
    We've checked the connections and the fuse in the panel, everything was ok. We're sending the mother bord and the screen to fanuc.
