Good to see you back, Greg.
By now, Fanuc has stopped making the 15A for > 30 years; I question the wisdom of anyone starting with a retrofit to use this; using existing servos and motors may justify it.
Personally, if you replace the servos and motors, I suggest going with an 16/18 iB control; just make sure that it does not have the option activation scheme.
