Fanuc 0TF , Leadwell 250 Lathe, Code G99, G96 not work
Good day. I have a Leadwell 250 Lathe with C-Axis, Fanuc 0TF. Problem with the cycle G99, G96. I bought it already with such a problem. When executing the program of these cycles, the spindle speed does not change. If I switch to JOG mode and move the X-axis, then everything is fine. The spindle speed is
changed. I don't have instructions with parameters. In which direction to look, I do not know. What to Watch?
