Hi! I work on a Doosan Puma 400XLM with Fanuc 21iTB with Manual Guide/EZ Guide I
There is this button in the edit screen named Mescyc which contains all kinds of measuring cycles. Most of which I can't use because we have no probe. But one pair of them are supposed to work with our Q-setter.
G2011 is the resulting command if I fill in the dialog. But I can't get it to actually run or do anything. I get an error stating "3135 error measuring 1st feed"
Does anyone have experience automating the Q setter or using the G2011 command?
I just want to rezero preset tools when I give them a fresh insert etc.
