Need Help! CNC does not work properly without HPCC
Results 1 to 1 of 1
Thread: CNC does not work properly without HPCC
    Member iildartt's Avatar
    Apr 2021
    Default CNC does not work properly without HPCC
    Hello everyone (Sorry for my English), I would ask you question about my problem with CNC. It happened when memory battery lost it's charge.
    If I turn on HPCC it works fine, but without it I can't use high speed. Example: If I want to make hole with diameter 52 mm by helical interpolation it makes it 50mm.
    Also I made pocket and the result you can see on picture.
    Attached Thumbnails Attached Thumbnails CNC does not work properly without HPCC-fanuc-jpg
