Need Help! Fanuc OM system hang!
Results 1 to 4 of 4
Thread: Fanuc OM system hang!
    Member Pritpalsingh362's Avatar
    Mar 2021
    Default Fanuc OM system hang!
    We are using Fanuc OM . From last two days the panel stops responding in between running program . When it happens the total machine stops working and panel gives no output. than we have to turn off and again turn on the machine and after 15 minutes same happened again .
    A week before machine showed a error 930 Cpu interrupt . But that error never came back till date .
    Please help us.
    Attached Thumbnails Attached Thumbnails Fanuc OM system hang!-661d2386-2e5b-4926-828b-8ac2920d3fe8-jpg
    Sep 2009
    India
    Default Re: Fanuc OM system hang!
    Please check the grounding of your drives and machine- this can sometimes be an issue and the noise from the high power panel causes the computer system to have issues.
    The CPU interrupt is usually caused by a power supply voltage issue to the best of my understanding.
    Do keep us posted if there is any development.
    Best regards
    JSS
    Mar 2021
    Thanks for your advise sir i will take a proper measures for machine grounding
    Mar 2021
    Quote Originally Posted by jaideepshinh View Post
    Best regards
    JSS
    Thanks !
    It seems like working . Not a single problem from last two days
