Need Help! should detect engine 3.0KW it detect as 18.5KW
Please see if you have an idea
The converter (FC300-3.0G-S2-B4C - 3.0KW AC220V VFD Frequency Inverter 15A 0-1000hz)recognizes my motor as an 18.5KW motor . P000 = Inverter model code identification 18, 18.5KW 220V
When my engine needs to show P000 = 6, 3.0KW/220V
It activates the motor for a second and then shuts it down and gives a fault of a overcurrent HoC
Thank you very much for your help .
