Robodrill T14ia Schematic
Results 1 to 2 of 2
Thread: Robodrill T14ia Schematic
    Apr 2012
    England
    Default Robodrill T14ia Schematic
    Hi, Can anybody help me with a schematic for a Robodrill T14iA. I am having issues with the machine not turning off after it has been on for a while and am trying to locate the relay that actuates the main contactor. Machine comes up with a KM1 weld alarm which id the main contactor. Any help would be very much appreciated.
    Aug 2011
    UK
    Default Re: Robodrill T14ia Schematic
    Robodrill T14ia Schematic-robodrill-jpg
    as you can see in the picture
    X20.7 needs to go off to switch off, so you need to check this input
    also when KM5 is energised it latches itself on, so make sure ON switch is not sticking in
    when you switch off check you have output from Y23.6 which operates KA12 which in turn releases KM5
    hope this helps
