It’s the same procedure as the main. You have to change Paths. The PMC parameters and ladder are shared by both paths so it is not required to load on the second path. To switch path there usually a button or a switch to change sides. If you don’t know how to switch paths look in the ladder for the “path change coil” G63.0 When G63.0 is off then path one is displayed, When G63.0 is on then path two is displayed.
