Originally Posted by
RaderSidetrack
Good to hear!
For future reference, while "crossover cables" may be needed for directly connecting a machine and a PC, crossover cables might be a specialty item if you want to purchase one locally. But inserting a cheap, readily available ethernet switch in-between the two directly connected devices is an alternative solution. Virtually all modern switches use Autonegotiation which eliminates the need for a crossover cable.
Also, if it looks like a "router" doesn't offer the option of assigning "static" IP addresses, look for an "Address Reservation" option. While they are not exactly the same thing, Address Reservation in a router would instruct the router to always use the same IP to talk to a machine, even though strictly speaking the machine is not set up as a static address. This process can be accomplished by the router because the machine has a unique MAC address that the router can recognize and remember when assigning an IP address.
