Dear all,
Recently I got a used Sram Card(Mitsubishi Melcard 1MB). I have to use this memory card for programs backup from Mori Seiki SL-250(Fanuc 18i-T).
For first when I get the card I changed backup battery(3V BR2325) with a new one because the old was completely discarghe. With the new battery I install the memory into a Sram/Pcmcia card reader for PC. When I turn on the laptop Windows message says : Memory card need to be formatted, format?
I chose not format the card because I am not sure if it is the correct way to perform that operation.
My question is the follow:
It is necessary to format Sram Card after internal battery backup failure for a long time?
SRAM cards have an external and internal rechargeable battery. If the external battery has been left dead for a long time, the internal rechargeable battery is now dead. Therefore, even if you replace the external battery, it will not work properly because the internal battery is damaged.
