We have a yang smv-1000 cnc machine with a fanuc 0M-D controller. this alarm comes up and I need to know where and how to LUBE these machines. I don't see a Vactra 2 reservoir. Do the use a grease gun? If so were is the Fitting for each axis? X Y Z Thanks for all your help!Similar Threads: Fanuc O-md Lube Time Alarm!!!!Problem- Alarm 1001 during probing, VM-2 Need help with yang smv-100 Error no.1001 lub time outNeed Help!- Lube Time Over Alarm/Single Block on
View Tag Cloud
Forum Rules
