Need Help! FANUC Oi-D SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR
Results 1 to 13 of 13
Thread: FANUC Oi-D SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR
    Nov 2008
    indonesia
    Default FANUC Oi-D SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR
    Hi, we need you help to solve my problem on Fanuc Oi-D alarm "SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR" suddenly appear after about one hours running. Attached are the picture of alarm
    Attached Thumbnails Attached Thumbnails FANUC Oi-D SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR-alm197-fanuc-oi-jpg
    Member kurmay's Avatar
    Aug 2011
    Default Re: FANUC Oi-D SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR
    I think , real alarm/error is
    PC050 IOLINK ER1 CH1:GR00:03
    https://www.facebook.com/okuma.tuning
    Nov 2008
    indonesia
    Quote Originally Posted by kurmay View Post
    What does it mean?
    Aug 2011
    I don't know but it seems PLC error.
    Dec 2009
    ROMANIA
    one of the I/O device is offline,maybe a fuse blown on the device,possible you have a short somewhere on the wires
    Oct 2009
    Mexico
    Quote Originally Posted by mluqman View Post
    Check the position of the axes when the alarm appears. It could be an intermittent short circuit . This is why the alarm PC050 IOLINK ER1 CH1:GR00:03 appears. If it happens even when the machine is not running, probably a bad PSU in the PLC rack.
    regards
    AlexFanuc
  7. #7
    Nov 2008
    indonesia
    Quote Originally Posted by alexfanuc View Post
    regards
    AlexFanuc
    I shutdown the machine and ON again after that the alarm PC050 IOLINK ER1 CH1:GR00:03 not appear anymore (like normal booting) but alarm display in the following
    OT alarm
    Turret alarm
    Emergency alarm
    I checked X input on the io status all the bits 0 that means the io not working.
    whe
  8. #8
    Dec 2009
    ROMANIA
    look on the PMC Maintenace screen, on the I/O LINK screen ad show us what you have there.
    FANUC Oi-D SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR-untitled-jpg
  9. #9
    Nov 2008
    indonesia
    Quote Originally Posted by zavateandu View Post
    Case close, the io at control panel defective
    thank you to all of you
  10. #10
    junlu691's Avatar
    Mar 2021
  11. #11
    Member THEZAM's Avatar
    Apr 2021
    Thumbs up Re: FANUC Oi-D SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR
    YOU CAN SHARE US MORE INFORMATION ON THE REPAIR OF THE FAILURE.
  12. #12
    Apr 2021
    HELLO COULD YOU HELP ME, I HAVE THIS INTERMITTENT ALARM IN MY MACHINE ..... FANUC Oi-D SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR .... WE RESET IT AND RESET BUT STILL WE CANNOT FIND ANY SHORT OR FUSE DAMAGED
  13. #13
    Member Parthi997's Avatar
    Nov 2021
    FANUC SYS_ALM197 EMBEDDED SOFTWARE SYSTEM ERROR results
    - - - Updated - - -
  14. #14
    Vic_Cam's Avatar
    Mar 2022
    Hi!
    How could you find the failure?
    I had a similar mistake in a fanuc controller, I check I/O link controller but nothing seems weird
