You set wrong number.
Hi guys and experts
After loosing references ( X,Y,Z - alarm #300 axis need REF ) I tried to fix
this problem by a help of some information that I got from a Fanuc technician
( step by step = MDI --> buton OFFET SETTING --> set write enable to 1 --> buton SYSTEM -->
dialog window PARAM --> 1815 NO SH --> APC APZ --> set APZ to 0 --> OFF/ON -->
manually axis to zero position --> change APZ to 1 and so on...
Well , I did it for Z axis first , everything was ok, I got rid of 300 alarm of Z ,
Then I started next step for X axis , but instead of PARAM --> 1815 --> NO SH
I started to search 1815 before I jumped into PARAM mode , so I could not get into
1815 parameters (I did not notice I am not in parameter setting menu )and I pushed
buton INPUT in this time
From this I can not get into dialog menu with PARAM DGN etc by pushing butun
SYSTEM . I switched machine ON/OFF a couple of times , tried lots of combination of
pushing lots of butons , without of success.
It seems like buton SYSTEM does not work . It does , but never into PARAM mode .
Is it possible to block buton SYSTEM by inputting some wrong number ?
Anything was lost ? Anything made some mishmash inside a system?
Did I jumped into something that I do not know how to jump out ?
I do not understand ...
What can I do ? I have a backup consist of 6 files ( DAT,DGN,LAD,PHL,PRG,PRM)
Could you give me any advice ? thanks a lot
Did you accidentally turn your EDIT KEY off so program and parameter setting are restricted?
I don't think you did anything else wrong. Hard to tell what screen you where at when you started typing again.
tuanpq
very usefull information ...
you spent 0,000001% of your iPhone battery to inform me that I set a wrong number.
quite good advice.....
I think,, facebook is better place to make some jokes...
thank you very much
Hello guys
for anybody who will need this information :
So , actually it is Fanuc 21i - MB ( AI 200 was only written at the LCD frame )
As I wrote, the main problem --- wrong inputting number 1815 into some parameters
that are seen in OFFSET SETTING , probably 3208 parameter because by reading
its value it was 0 0 0 0 1 1 1 1
According to the manual , bit #0 marked as SKY can be used for blocking button SYSTEM
So , it happened ( I suppose number 15 from "1815" was interpreted as 1 1 1 1
and rewrote 3208 .
I would like to thank to alex of mexico who gave me a hand to discover it .
So , I changed 3208 to 00000000 and I was able to get into parameters menu
via button SYSTEM and finished what I wanted .
