Need Help! Memory card not exist!
Results 1 to 3 of 3
Thread: Memory card not exist!
    Member Ariful-Islam's Avatar
    Apr 2019
    Default Memory card not exist!
    I want to take SRAM backup to USB pendrive on Fanuc CNC lathe machine.
    Model number Oi Mate TD (D7 F1-34.0).
    System Monitor Main Menu shows 'Memory card not exist', though i have changed I/O channel 17 and pendrive is plunged in.
    Should i change any parameters to take SRAM backup to USB pendrive?
    Can any one help me about this problem?
    Apr 2009
    Default Re: Memory card not exist!
    I am a little confused by the title "DRPINT IN MEMORY CARD....".
    From what you described, it sounds like you want to make an SRAM backup of the machine memory to a USB device? This is normally done in the boot screen using a memory card. The boot screen does not support USB.
    You can make an SRAM backup to a USB device but you will need to boot up in IPL mode.
    Hold " - " (minus) and " . " (decimal) in while booting up. It takes some time for the screen to appear so be patient.
    Select BATCH DATA BACKUP / RESTORE (12)
    Select BATCH DATA BACKUP CNC TO USB MEMORY (11)
    You can also restore the SRAM from IPL
    [url]www.shoprag.com[/url]
    Apr 2019
    Shoprag
    Thanks a lot.
