Need Help! STAMA MC 530 1995 FANUC 16M all parameter lost - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 43
Thread: STAMA MC 530 1995 FANUC 16M all parameter lost
  1. #21
    Default Re: STAMA MC 530 1995 FANUC 16M all parameter lost
    I have CNC parameters on my PC computer. Is there any option to load them from the memory card? I know how to do this, but I don't know what format the file should be in.
  2. #22
    Apr 2011
    Quote Originally Posted by pablowlkp View Post
    It has to be loaded VIA RS232. On your controller the MEMORY CARD only works in the Boot mode and on the PMC side. Here is what I have to show you how to load.
    Attached Files Attached Files
  3. #23
    Quote Originally Posted by drdos View Post
    Thanks.
    I have a problem to load cnc parameters. I don't have read/punch mode. System/oprt/ softkey (>).
    I can't select Edit mode, only emerygency stop.
    Attached Thumbnails Attached Thumbnails STAMA MC 530 1995 FANUC 16M all parameter lost-20210107_151205-jpg   STAMA MC 530 1995 FANUC 16M all parameter lost-20210107_151210-jpg
  4. #24
    Apr 2009
    As I stated before: Loading system files and parameters should be done in MDI mode (default) and E-stop condition.
  5. #25
    Quote Originally Posted by memoryman View Post
    I have press e-stop but I can't press MDI mode because my ladder is stopped and the MDI key is inactive.
    Attached Thumbnails Attached Thumbnails STAMA MC 530 1995 FANUC 16M all parameter lost-16100307374341708568018167396936-jpg   STAMA MC 530 1995 FANUC 16M all parameter lost-16100307549532774254878662559469-jpg
  6. #26
    Apr 2009
    MDI mode is the default, so doesn't have to be selected.
  7. #27
    Oct 2009
    Mexico
    Enter parameters 9900 thru 9960 by hand , power off and on . Then you will be able to see the "READ" option.
    Regards
    AlexFanuc
  8. #28
    Quote Originally Posted by alexfanuc View Post
    Regards
    AlexFanuc
    READ/ PUNCH option back. Thanks ALEXFANUC.
    Is there any parameter that is responsible for reading parameters from the PC to FANUC?
    I have sent parameters from FANUC to my PC but I am having trouble sending data from PC to FANUC. (parameters set for Fanuc 16)
  9. #29
    Apr 2011
    Did you read the PDF file I sent you?
  10. #30
    Apr 2006
    Viet Nam
    Enter option parameter first
  11. #31
    Yes, I have read your pdf.
    I loaded cnc parameters and pitch error, but i have a problem with loading pmc parameters. When I try to upload PMC, I have alarm 087. (keep relay 17.1 to 1).
    Where can I find them? do they start with parameter 60000? Do I have to change any parameter to make them visible?
    In the attachment the PMC parameters that I have.
    Can someone explain something to me?
    I was able to upload cnc parameters to the machine only with PC parameters: Baudrate 4800, none parity, stop bit: 1, Baund rate 8. Other parameters didn't work.
    I changed the parameters in Fanuc to different ones: baudrate to 4800 or 2400, par 0020 I/O channel: 1 or 0; parameter 0112 device no : for different values and it didn't affect the data upload. I do not understand it.
    Attached Thumbnails Attached Thumbnails STAMA MC 530 1995 FANUC 16M all parameter lost-pmc-jpg
  12. #32
    Apr 2011
    The PMC parameters have their own Baud Rate. It is either 4800 or 9600. Also when all memory has been cleared the channel switches to 0 it needs to be set to a . You have to find the soft key that says channel and type 1 then press the channel soft key.
  13. #33
    Oct 2009
    Mexico
    Hello.
    DM me.
    Regards
    AlexFanuc
  14. #34
    Hello.
    DM me.
    Regards
    AlexFanuc
    I wrote a PM to you.
  15. #35
    Hello
    Thanks for all to help. Problem was solded. Problem was solved. I got a backup from Fanuc because rs232 transmission is not possible.
  16. #36
    Mar 2013
    Slovenija
    hi , I think I will have the same troubles. Hope not, but I go t a Stama MC530 machine from 1994, and I will start setting it up slowly. I hope you guys here will be able to help me. I am really new to this thing. Of course I have to connect the machine to the electricity and see what will say before I can do anything.
  17. #37
    Mar 2013
    Slovenija
    Hi, today I connected the machine to the electricity and tried to start up. What I got was a blinking SU-01 code in the main NC unit. I heard that fan was spinning and nothing showed up on the display. I tried to press the green button on the display but nothing showed. Any ideas on what this is ?
  18. #38
    Dec 2009
    ROMANIA
    Please post a picture with the led sequence form the MAIN
  19. #39
    Mar 2013
    Slovenija
    Quote Originally Posted by zavateandu View Post
    Hello zavateandu, what exactly you mean with "MAIN" ? Sorry I am new to this thing. I upload some pictures, which could probably help.
    Attached Thumbnails Attached Thumbnails STAMA MC 530 1995 FANUC 16M all parameter lost-whatsapp-image-2022-12-02-22-34-a   STAMA MC 530 1995 FANUC 16M all parameter lost-whatsapp-image-2022-12-02-22-34-a   STAMA MC 530 1995 FANUC 16M all parameter lost-whatsapp-image-2022-12-02-22-34-a   STAMA MC 530 1995 FANUC 16M all parameter lost-whatsapp-image-2022-12-02-22-34-a
  20. #40
    Dec 2009
    ROMANIA
    STAMA MC 530 1995 FANUC 16M all parameter lost-main-jpg
