Maybe it can be changed in parameter 3706 If you change bit #5 (ORM). The value can be 0 or 1.
But what do you gain from having it going M3 instead?
Is there a way to change which direction the spindle spins when it orientates? Currently it spins in reverse(mo4). FANUC 31i- Model B it's a live tooling OM VTL
Im sorry, did't read your question to end. Assumed it was a lathe.
Have you read this http://www.helmancnc.com/fanuc-g76-f...ycle-cnc-mill/
Dont know if it can be any help.
Gl
