Need Help! wasino profile grinder fanuc om can't input pc parameters
Results 1 to 19 of 19
Thread: wasino profile grinder fanuc om can't input pc parameters
    Member sedm's Avatar
    Nov 2020
    Default wasino profile grinder fanuc om can't input pc parameters
    I'm working on a wasino profile grinder with fanuc om controller that lost its memory. I input the nc parameters and tried to do the pc(diagnostic) parameters but it will only allow me to imput #500-509. I have all the remaining parameters to input but it won't take them? Any ideas?
    Oct 2009
    Mexico
    Default Re: wasino profile grinder fanuc om can't input pc parameters
    Quote Originally Posted by sedm View Post
    What is the alarm that you have right now?
    From what number ( PC diagnostic) are you trying to input the parameters?
    Regards
    Alex Fanuc
    Nov 2020
    No alarms. All the diagnostic parameters except # 500 thru 509. I was able to input those. Machine won't home.
    Oct 2009
    Mexico
    If the machine will not zero return, then you must check NC parameters.
    What do you have in parameter 21 and 22?
    Alex Fanuc
    Nov 2020
    Quote Originally Posted by alexfanuc View Post
    Alex Fanuc
    Parameters 21 and 22 are all zeros.
    When trying to home it gives a 501 error y overtravel alarm but it only travels .075(inch)
    And if I go in the other y direction, it only goes .075 that way and trips the alarm??
    Thanks for your help!!
    Oct 2009
    Mexico
    Hello ,
    then you must open the software limits.
    prm 700 (stroke limit + direction) for x axis (write down the actual number ) make it 99999999
    prm 701 (stroke limit + direction) for z axis (write down the actual number ) make it 99999999
    prm 704 (stroke limit - direction) for x axis (write down the actual number ) make it -99999999
    prm 705 (stroke limit - direction) for z axis (write down the actual number ) make it -99999999
    Regards
    Alex Fanuc
  7. #7
    Nov 2020
    What are the parameter numbers for the y axis. Its a profile grinder and only has x&y axis.
    Thanks again
  8. #8
    Oct 2009
    Mexico
    Thanks again
    The parameters that I stated apply for the Y axis. Instead of Z axis those parameters apply for the Y axes
    Remember that when changing those parameters, the axes will not stop until the reach the hardware overtravel switch. If the hardware overtravel switch malfunction, you may damage the screwball.
    Regards
    Alex Fanuc
  9. #9
    Nov 2020
    With those parameters input, when I try to home it. An error 426 (y axis disconnect) comes up now. I'm going to try taking the servo connections off and cleaning them with electrical contact cleaner?
  10. #10
    Oct 2009
    Mexico
    How about the X axis? Does it home?
    Alex Fanuc
  11. #11
    Nov 2020
    Yes the x axis seems fine. The y axis seems to vibrate when you jog it. Then as soon as you move it fast, it kicks the alarm. I"m thinking the servo needs tuned for the y axis?
  12. #12
    Nov 2020
    Opps, I was wrong, it gives an alarm 90 when doing a zero return in the x axis. But it does move nice and smooth in the x axis as compared to the y.
  13. #13
    Oct 2009
    Mexico
    If the axis vibrates and the machine lost memory, I would look into the 8200 parameters. First solve this problem, then we will look into the alrm 90 in the X axis.
    Alex fanuc
  14. #14
    Nov 2020
    I found that 8203 parameter was incorrect. I changed it and now the vibration is gone. And I found that the limit switch(deceleration)was set incorrectly for the x axis. The machine now homes!!!!
    The only thing that doesn't seem to work is the multiplier. When I crank the handles it moves in slow speed regardless of the multiplier setting( x1, x5,or x10). Any ideas?
    Thanks so much! You've been so helpful. Rich
  15. #15
    Nov 2020
    Correction......The multiplier is working just not in the same ratio it did previously. On x1, 1 turn on the handwheel =.001(inch) and x5 =.005 and x10=.010. It works fine this way, just different ratio than previously. We used to grind on x5 before. Now we grind on x10 to make it feel the same.
    Thanks again for all your help. I couldn't have got it running without your help! Rich
  16. #16
    Nov 2020
    Any help on an alarm 11. It occurs when trying to do taper in automatic mode(forward or back buttons) the taper works fine if I crank the handles but not in auto mode??
  17. #17
    Oct 2009
    Mexico
    Hello:
    Check the feedrate. Did you command feedrate?
    Regards
    Alex Fanuc
  18. #18
    Nov 2020
    No, I didn't command a feed rate. The grinder manual says its variable macro #500 and to consult the fanuc operators manual which I don't have. How do I set a federate?
  19. #19
    Nov 2020
    Never mind, I found it. It was in menu offset button.
    Thanks again, Rich
