- Need Help!- Kao Ming KMC-2000SD (M03/M04 do nut work)
Hello,
I have Kao Ming KMC-2000SD with FANUC O-M, and it was working properly.
One week ago it stopped respond to M03/M04 commands without any alarms, while the spindle respond to M19 command and return to it's ATC position
I have checked all hardware items(valves, sensors, air presser, oil ...etc.) everything is OK.
Does anyone have an idea about this issue?
Thank you all in advance
Re: Kao Ming KMC-2000SD (M03/M04 do nut work)
Hello,
We have a Kao Ming KMC-2000SD similar with yours.
Our parameters erased and we need a software backup.
Can you help us please.
Regards.
Yasin.
- You may not post replies
- You may not edit your posts
Forum Rules
