Fanuc 18i-P
Results 1 to 5 of 5
Thread: Fanuc 18i-P
    ozonair's Avatar
    Sep 2018
    Post Fanuc 18i-P
    We need help how to upload machine software and parameter files to machine Amada Europe 258 with Fanuc 18i-P.
    We have machine files for Amada Europe 258 on SRAM disk:
    A8DX_04.MEM
    P903_01.PAR
    P903_01.PMC
    P903_01.TOL
    M9X3_01.MEM
    A8DX_04.MEM and M9X3_01.MEM uploading is successful, but we can not upload .PAR, .PMC and .TOL files. When try to upload .PAR, .PMC and .TOL files in the machine we receive error SRAM0_5A.FDB NOT FOUND
    Any help?
    Should we convert .PAR, .PMC and .TOL to .FDB file and how?
    Apr 2011
    Default Re: Fanuc 18i-P
    The PAR, .PMC and .TOL files have to be loaded via the RS232 port not the Boot mode
    ozonair's Avatar
    Sep 2018
    You mean that we have to upload only MEM files through boot mode? Than how to proceed to loading via the RS232?
    We do not receive main screen of the machine after loading MEM files.
    Attached Thumbnails Attached Thumbnails Fanuc 18i-P-main-screen-jpg
    Apr 2011
    I can't see the attached files. What problem did you have that made you believe that you needed to load these files? The MEM files are stored in FLASH memory and don't need to be loaded.
    Apr 2006
    Viet Nam
    Par file is parameter
    Pmc file is pmc parameter
    Tol file is tool setting
    Mem file is flash memory file
    ozonair's Avatar
    Sep 2018
    During replace of the monitor screen, we have disconnected battery. From this point we have lost main machine screen, with Amada logo and all other options. On normal start up we have black screen. On service start up we have system main menu with options as 1. system data loading 2. system data check............
    We need help how to revert back to main machine screen to operate the machine
    https://en.industryarena.com/forum/a...5&d=1605972156
    check the picture of the main machine screen we are missing
  7. #7
    Apr 2006
    Viet Nam
    Quote Originally Posted by ozonair View Post
    There is a way to replace the screen without removing the battery.
    If you lost option, You should contact to Amada
Fanuc 18i-P
Fanuc 18i-P
Fanuc 18i-P
