...MDI > G54X0Y0 to activate Work Offset 1
G28X0Y0Z0 for machine zero most likely
I have an old machine centre with a Fanuc om control.
I move the machine to the position where I want x0 y0 z0 to be.
I copy the machine coordinates to work offset 01.
When I go to auto and press cycle start the machine goes to some other random place.
Also if I move the machine from x0 y0 z0 and press reset it resets my absolute coordinates back to zero.
Is there a parameter that I need to change or am I going the wrong way about setting it up?
Tried that and its active. Ive used alot of machines and ive never had one do this before. I know some machines when you set your work offsets dont change the abs until you hit reset but this one zeros the abs when you press it.
It's easy, I have the fanuc OM-D, you just need to zero the machine first. And all is done.
Sent from my CPH1819 using Tapatalk
Check parameter 394 bit 6 should be 0
parameter 394 bit 6 is 0 already.
do you have any key on the panel called ABSOLUTE/INCREMENTAL ? maybe that key is enabled?
