Do you have a key lock on the control you have turned by accident?
Dear all
my CNC mill machine lock message came on since the beginning of this month, and I am totally unable to operate it any more. It always refers me to contact the dealer of the machine
I thought to bring back the date to a date earlier than the date it brought this message into view, but when I try to modify the date , I always face a write protect message even if l entered the PMC password
I thought also to modify the ladder program using Fanuc ladder III program, but I lost inside the code due to not knowing the correct parameter to modify.
my controller is "Fanuc Oi-MF Plus" series with version "D4G3-06.0"
Machine is "SINO VMC1060B"
you may find some more information in the attached screen shots
thanks in advance for reply
No I don't, because I was able to change the parameter write field from 0 to 1 , but it is useless
You try to modify parameter. if you can't modify parameter then your machine may password protect. you contact to machine manufacturer.
That's why i am here to know if it is possible to modify the machine without consulting the manufacturer, if it is not possible to modify the parameters Via the controller, is it possible to modify the parameters file then upload the modified file to the controller or not ? and what is the process for uploading
dear hi
we have amada pega 345 king with 58 st and 2 AI , fanuc 6 controller , made at 1986,the machine lost all memory, we have not parameters , pc parameters and diagnuse files , locking for same this type machine to copy all parameters, pls how can help?
...Is this Software Leased? I see the build/program Date was 2019/11/1 by WANG one year would be just two weeks from now. That would also explain the Locked out clock
I don't get the relation... what's the relation between the build/program date and the lock date ? the machine lock date was 01.oct.2020 that means 11 months of operation which is odd, not 12 month , not 10, not 6, nor 5 , I guess it is just related to the maintenance schedule or something, I will post the machine lock screen expiry date whenever possible
That is a Fanuc generated alarm, you are not going to fix it by ladder edit. Fanuc controls this not the machine tool builder. But the machine tool builder has a way to unlock it. I am betting you don't want to pay the machine tool builder that is why this message is active. But there is no "back door" to this fix.
YAP,you have to pay the lady!
I think the time is in the hard drive .
