Need Help! Fanuc 0TD
Results 1 to 4 of 4
Thread: Fanuc 0TD
    Member PS85's Avatar
    Jun 2020
    Default Fanuc 0TD
    I have a CNC with a fanuc 0-TD controller. The X axis is not moving exactly to where it is commanded. If it is commanded to go to X0, Z0 , it only follows the command on the Z axis but falls short in the X axis. My parts have larger dimensions only in the X axis. Z axis dimensions are to scale. Workshift and work-offsets were set properly.Wear offsets are cleared to all zeros. Any fixes to this kind of problem?
    May 2016
    Default Re: Fanuc 0TD
    99.99999% of the time a machine is going to do exactly what it is told to do. You don't give any history behind your story. Is this a brand new to you machine and this is your first run? Or has this machine been running fine on other jobs but not now on this one?
    I bet you messed up somewhere when setting tool or work offsets. Happens to all of us. Machines don't typically move randomly. They're not smart enough for that. They simply do what they're told to do. Nothing else.
    Dec 2003
    When you zero the machine, does it show zero position?
    If not, you have a zero offset entered.
    If not, you most likely have a work offset command.
    May 2016
    United Kingdom
    What machine do you have?
    How are you measuring your offsets?
    Check what Al said as maybe an offset in your worksheet page
Fanuc 0TD
Fanuc 0TD
Fanuc 0TD
