I have a Daewoo 6s lathe the battery died so I lost everything.
I do have a 14 page printout of settings to use. I have input lines 001 too 8000+ manual typed in.
I have not had any luck in getting machine to start up. But have no alarm codes to help me sort it out. There is a lot of data I can not find where to input like n900 etc
I think it might be much more simple if someone here had a file I can upload to machine to get it to start up then edit parameter's to fine tune machine
Re: FANUC SERIES O-T parameters needed Daewoo puma 6s
Hi Wojtekthx,
Could you help me with your Puma 6s parameters?
I am needing to double check against my parameters, thank you!
Having some issues measuring tools and displaying the measured offset in absolute.
