Need Help! Hi
Results 1 to 5 of 5
Thread: Hi
    Member Hassanhac's Avatar
    Sep 2020
    Default Hi
    I need help
    I have got cnc machining center with fanuc m15 control
    I have lost all parameters
    I won't fanuc m15 parameter manual
    I wont to readjust the parametrs
    Now only x axes appear on the screen
    I wont to adjust the numbers of axis controller
    The machine have 5 axis
    Can you help me to get the parametrs please?
    Apr 2011
    Default Re: Hi
    You are going to have to give us a lot more information than that. Those parameters are defined by Fanuc but set by the builder. You will never get this machine running by simply guessing what value to put into which parameters. Whose the builder, which model, 15MA or 15MB, it all matters
    Sep 2020
    Quote Originally Posted by drdos View Post
    Hi
    I made a mistake and i lost machine parameter
    I repack it again manually but machine not working
    I will send you all information
    Please call me
    00905418167717
    Hassanhacmusa@gmail.com
    Attached Thumbnails Attached Thumbnails Hi-16010980975919194940283440749595-jpg   Hi-16010981240351890937061321687792-jpg
    Sep 2020
    Hi
    Please call me
    00905418167717
    Sep 2020
    I think my problem is her
Hi
Hi
