Need mill to feed hold when door opens
Results 1 to 5 of 5
Thread: Need mill to feed hold when door opens
    Mar 2018
    Default Need mill to feed hold when door opens
    I have a Agma VMC with a 0i-MD control. When the door is opened the spindle stops but the axis keep feeding. Does anyone know what parameter or keeper will also put the machine into feed hold?
    Apr 2011
    Default Re: Need mill to feed hold when door opens
    Can you post your ladder? Coil G8.5 in the ladder need to turn off with the door open.
    Mar 2018
    Quote Originally Posted by drdos View Post
    Here is a screenshot of G8.5 in the ladder
    Attached Thumbnails Attached Thumbnails Need mill to feed hold when door opens-20200922_075156-jpg
    Member cncmakers001's Avatar
    Jul 2011
    China
    Quote Originally Posted by ONyX557 View Post
    There could be a Safety door switch like D4NL-1DFA-BS-F OMRON, maybe you can disable it.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jan 2014
    Quote Originally Posted by cncmakers001 View Post
    why would you disable it?
    You need to know when the door is opened to accomplish what he is asking " to feed hold the machine"
    DRDOS has it correct.
    But can you back up the logic and send it to us or attach it.
    The photo does not show enough to help you.
