Denford Triac fanuc O-M Datum problem
Results 1 to 3 of 3
Thread: Denford Triac fanuc O-M Datum problem
    Default Denford Triac fanuc O-M Datum problem
    Hello
    I bought a Denford Triac milling machine on Fanuc O-M and after a short time I noticed that the axes could not be homed. Manual axes movement works ok, no alarms are displayed when I try to homing the axes. I made a backup of the parameters parameters. In the attachment I added copies of parameters and diagnostics, maybe someone will notice a problem why I can't datum the axes . Best regards
    Attached Files Attached Files
    Apr 2011
    Default Re: Denford Triac fanuc O-M Datum problem
    Try powering down the control then press and hold the P and CAN buttons while it powers up. Make sure that you jog the axis away from the home position on all the axis before trying to home.
    hi
    Unfortunately I tried it already.
