I am using a Nakamura-Tome sc300 lathe from 1998. It has required a new cpu and upgraded system software.
It is producing an error when using the Super-Cap software , in simulation or when running the program to execute
sets up a error of W605 L-UNIT RESET
I can't find that error code in the books anywhere.
Any ideas as to what this may be caused by?
Controller is an 18i TA with LuckBei software.
AN Update.
I found that if I just use the curser and chose the left arrow, it will go back to the previous screen. If I then press the animation again, it will just run as normal. If I press the reset button, I stay in the loop of the W605 error.
Same with running the program. If it goes to W605, just curser to the left, and re run that area or the main exe and it runs just fine.
No idea why at all, but is now working.
In the ISO mode or Gcode mode, this W605 error does not occur.
Neil
AN Update.
Neil
