Hi sir,
Rename to O1234.txt, should work.
The M198 command uses files without extension.
regards.
My CAM software writes programs with an extension .NC at the end of the program number ( O1234.NC), My CNC machines will not recognize this when I am trying to upload it to the machine from a USB. I have been renaming the file with no extension and it works great. But now that I am using Windows10 I am having trouble renaming a file with no extension. Is there a way to get the machine to recognize the file with a .NC extension?? to avoid renaming all together
Greg
- Newbie- ENG file extension
- Need Help!- milltronics file extension
- Need Help!- Opening CDR file extension.
- post file extension
Hi sir,
regards.
...edit your Cam post process to Save as .txt (ANSI)
