Problem Electronics Fault
Results 1 to 5 of 5
Thread: Electronics Fault
    Member HamzaB's Avatar
    Jul 2020
    Default Electronics Fault
    Hello Sir, we have a Turret Punch Press Strippit 1250 MH machine which controller is GE Fanuc O-P Series . We have this problem that the controller is not booting.Please tell me solution.
    Attached Thumbnails Attached Thumbnails Electronics Fault-inbound989248744208046019-jpg   Electronics Fault-inbound3956357218232225849-jpg
    Member Deepak83's Avatar
    Jul 2020
    Default Re: Electronics Fault
    Hi
    if you can make a small video and send it to me, it is better to understand me and accordingly I can explain it to you.
    Regards
    Deepak
    Jul 2020
    Quote Originally Posted by Deepak83 View Post
    Hi
    Regards
    Deepak
    video is not being uploaded to this forum.this is model of our machine Strippit Fc 1250mh,Controller GE Fanuc O-P Series.The control does not ON.The machine would turn off as soon as the power ON
    Jul 2020
    Do you have any procedure to boot the controller?
    Jan 2014
    You may have a short somewhere. As the controller boots up and sends control power out to sensors and outputs, one shorted could draw down the power supply and shut the control back off. Seen it many times.
Electronics Fault
Electronics Fault
