Fanuc O-T on Emco 320 bar feeder removed need to disable bar feeder in the logic
I have a Emco 320 / Fanuc O-TC that is configured with a LNS Hydrobar bar feeder. I have the lathe powered up but the Lathe is expecting a bar feeder to be connected and its not available right now.
I'm not sure how to "disable" the bar feeder, is it setup in the parameters and if so which one, or do I need to jumper out the Bar feeder or something like that.
I can't continue troubleshooting the actual alarm that appears when the bar feeder ic connected.
Re: Fanuc O-T on Emco 320 bar feeder removed need to disable bar feeder in the logic
ussually you need to jumper the emergency contact from barfeeder.
if it is any other signal that enables the barfeeder that must be in diagnose
if you have the diagnose printed out and have comment on it will be easy to see what bit is enable it.
