What controller do you have? is it possiable to post the ladder so we can take a look at it?
Please help. I wants alarms back.
I have just bought an old Feeler FV600 milling machine and it is not showing alarms fx. door open, Spindle Oil cooler alarm and Air pressure low alarms are not shown on the monitor. The alarms are working, cause I cannot move the XYZ axis when the door is open. And I cannot start the spindle without the Oil cooler is connected. Some alarms are shown on the monitor fx. overtravel alarm are shown.
I think it is a parameter that are wrong, but I have no idea which one.
On an old machine like that, it's completely possible that the devices and sensors that signal the control about the state of the machine's ancillary equipment are either non-functioning or disconnected. If possible, check the X adresses for each signal device, whether by manual manipulation or meter check. If you're not getting bit changes, then the sensors are your problems and the alarms are potentially functioning. It you're getting bit changes with sensor actions and still no alarms, then your problems are deeper then I have the skills to help you with.
I don't recall many if any instances where the MTB gave you control over forcing alarms off permanently. There might be a few, but if it were my guess, door interlocks and low air wouldn't be on that list.
Hi drdos.
It is A Fanuc 0M and C version. How do I make a Ladder export? Can you use a backup of PMC diagnostic parameter?
PMC parameters:
N10300 P 00000000
N10301 P 00000000
N10302 P 00000000
N10303 P 00000000
N10304 P 00000000
N10305 P 00000000
N10306 P 00000000
N10307 P 00000000
N10308 P 00000000
N10309 P 00000000
N10310 P 00001010
N10311 P 00000000
N10312 P 00001100
N10313 P 00000000
N10314 P 00000011
N10315 P 00000010
N10316 P 00000000
N10317 P 00110101
N10318 P 01110010
N10319 P 00000000
N10320 P 00000010
N10321 P 00000000
N10322 P 10111010
N10323 P 10010110
N10324 P 00000000
N10325 P 00000010
N10326 P 00000000
N10327 P 10010101
N10328 P 00000000
N10329 P 00000000
N10330 P 00000010
N10331 P 00000000
N10332 P 00000000
N10333 P 00000000
N10334 P 00000000
N10335 P 00001010
N10336 P 00000000
N10337 P 00001100
N10338 P 00000000
N10339 P 00000011
N10340 P 00000100
N10341 P 00000000
N10342 P 01011000
N10343 P 01000100
N10344 P 00000000
N10345 P 00001010
N10346 P 00000000
N10347 P 01100001
N10348 P 01000100
N10349 P 00000000
N10350 P 00001010
N10351 P 00000000
N10352 P 00000000
N10353 P 00000000
N10354 P 00000000
N10355 P 00101110
N10356 P 00000000
N10357 P 01011011
N10358 P 11111110
N10359 P 00000000
N10360 P 00000000
N10361 P 00000000
N10362 P 00000000
N10363 P 00000000
N10364 P 00000000
N10365 P 00001010
N10366 P 00000000
N10367 P 10101100
N10368 P 00000010
N10369 P 00000000
N10370 P 00000100
N10371 P 00000000
N10372 P 10000111
N10373 P 01000100
N10374 P 00000000
N10375 P 00000111
N10376 P 00000000
N10377 P 00000000
N10378 P 00000000
N10379 P 00000000
N10380 P 00001010
N10381 P 00000000
N10382 P 10110101
N10383 P 01110100
N10384 P 00000011
N10385 P 00001010
N10386 P 00000000
N10387 P 11000000
N10388 P 01110100
N10389 P 00000011
N10390 P 00101100
N10391 P 00000001
N10392 P 00010000
N10393 P 01000101
N10394 P 00000000
N10395 P 01110000
N10396 P 00010111
N10397 P 10000001
N10398 P 01011100
N10399 P 00000000
N10400 P 00001010
N10401 P 00000000
N10402 P 00000000
N10403 P 01101100
N10404 P 00000000
N10405 P 00000000
N10406 P 00000000
N10407 P 00000000
N10408 P 00000000
N10409 P 00000000
N10410 P 00000000
N10411 P 00000000
N10412 P 00000000
N10413 P 00000000
N10414 P 00000000
N10415 P 00000000
N10416 P 00000000
N10417 P 00000000
N10418 P 00000000
N10419 P 00000000
N10420 P 00000000
N10421 P 00000000
N10422 P 00000000
N10423 P 00000000
N10424 P 00000000
N10425 P 00000000
N10426 P 00000000
N10427 P 00000000
N10428 P 00000000
N10429 P 00000000
N10430 P 00001010
N10431 P 00000000
N10432 P 00000000
N10433 P 00000000
N10434 P 00000000
N10435 P 00001010
N10436 P 00000000
N10437 P 00000000
N10438 P 00000000
N10439 P 00000000
N10440 P 00100010
N10441 P 00000000
N10442 P 00100000
N10443 P 00000000
N10444 P 00000000
N10445 P 00011000
N10446 P 00000000
N10447 P 00100000
N10448 P 00000000
N10449 P 00000000
N10450 P 00000000
N10451 P 00000000
N10452 P 00000000
N10453 P 00000000
N10454 P 00010111
N10455 P 00000000
N10456 P 00000011
N10457 P 00000000
N10458 P 00000000
N10459 P 00000000
N10460 P 11111111
N10461 P 11001111
N10462 P 00000000
N10463 P 00000000
N10464 P 00000000
N10465 P 00000000
N10466 P 00000000
N10467 P 11100010
N10468 P 10110111
N10469 P 00000000
N10470 P 00000000
N10471 P 00000000
N10472 P 00000000
N10473 P 00000000
N10474 P 00000000
N10475 P 00000000
N10476 P 00000000
N10477 P 00000000
N10478 P 00000000
N10479 P 00000000
N10480 P 00000010
N10481 P 00000000
N10482 P 00011000
N10483 P 00010000
N10484 P 10000010
N10485 P 00000001
N10486 P 00100000
N10487 P 00000000
N10488 P 00000000
N10489 P 00000000
N10490 P 00000110
N10491 P 00000101
N10492 P 00000000
N10493 P 00000000
N10494 P 00000000
N10495 P 00000000
N10496 P 00001000
N10497 P 00000000
N10498 P 00000000
N10499 P 00100000
I have found the problem . It was the parameter 906#6 EXTERNAL MESSAGE that was 0 It need to be 1 on Feeler FV to send messages from the PMC-L
No, that is a PMC Ladder Cassette for the series 15A. What I am talking about is an EDIT Cassette A02B-0098-C199. They were field service/OEM issued only. If you find one make sure that you have everything backed up before using I had a few machines go into RAM parity alarm when using them.
