Fanuc -18 (MATSUURA 450) parameter for hold tool in spindle
Hi!
I need help to find parameter.
The double arm of the machine insert tool in the spindle. I need to know the timeout to hold the tool befor turn the double arm back.
My timeout is small now and the spindle did not clamp the tool and double arm take of the tool from spindle.
Can anybody know where to dig?
Re: Fanuc -18 (MATSUURA 450) parameter for hold tool in spindle
The setting will probably be in your DATA tables. You will need the machine builders information as to what bit to change. This will not be a Fanuc parameter.
The problem you're having is not because of the timer being too short, but something is wrong in the tool pusher. Check you air/hydraulic release cylinder for leaks or low oil level. Bleed the hydraulic lines for the tool release. Air in the system will slow the release or cause it to fail.
The timer worked in the past. It should also work in the present, unless somebody messed around with it.
