Need Help! Fanuc 21i TB
Results 1 to 4 of 4
Thread: Fanuc 21i TB
    Member positiverake's Avatar
    Sep 2005
    Default Fanuc 21i TB
    Hello all, machine is a doosan puma 700 m with fanuc 21i TB, problem is after setting the Q-setter (re-calibrate) it wont pick up the wear offsets ? re-touched off using the geometry set off the part (no Q-setter) and it worked fine? anybody no what parameter 5020 (ofs no) is used for? thanks
    May 2016
    United Kingdom
    Default Re: Fanuc 21i TB
    What do you mean it won't pick up the wear offset
    Sep 2005
    Hi mb, the machine does not read the wear offset, it does not adjust to it
    Sep 2005
    Shut the Machine all the way down and now it works fine
Fanuc 21i TB
Fanuc 21i TB
Fanuc 21i TB
