Need Help! Programming with G10
Results 1 to 4 of 4
Thread: Programming with G10
    Member Rukam22's Avatar
    Sep 2019
    DARFIELD
    Default Programming with G10
    Hello guys,
    I want to modify parameter 3772 from 12000 to 30000 because I use 2 different motors, with G10 in program? I don't know how to program.
    Apr 2011
    Default Re: Programming with G10
    It all depends on the controler that you are using.
    Sep 2019
    DARFIELD
    The controler is Fanuc 31i model B
    Apr 2011
    My book says parameter 3772 is Maximum Spindle Speed
    To change VIA G10:
    G10 L52 ; Parameter entry mode setting
    N3772 R12000
    G11 ; Parameter entry mode cancel
    N_ : Parameter number
    R_ : Parameter setting value (Leading zeros can be
    omitted.)
    P_ : Axis number 1 to maximum controlled axis number (to
    be specified when an axis type parameter or spindle
    type parameter is specified)
