Need Help! How to disable a tool pot?
Results 1 to 10 of 10
Thread: How to disable a tool pot?
    Member Rukam22's Avatar
    Sep 2019
    DARFIELD
    Wink How to disable a tool pot?
    Hi guys,
    Can you help me how to disable a tool poot in the tool magazine? Because I broke the tool pot and I don't want to use it anymore.
    Controller is Fanuc 0i-MF
    Magazine is with 24 tools pots.
    May 2016
    Default Re: How to disable a tool pot?
    The machine builder will have a tool number to tool pot table in the diagnostics. Without knowing the diagnostic numbers where they're stored it could be difficult to determine which tool is currently assigned to the broken pot. In that case do this.
    MDI T0M6
    This will call tool zero to the spindle.
    If this brings a tool to the spindle, remove it.
    Now manually rotate the carousel until the broken pot is in the tool change or active position.
    Now MDI M6
    This will now install T0 into the broken tool pot.
    Now never program or use T0 in your programs or daily routines. It's likely that you don't anyway.
    If you know which diagnostic parameters control the tool pot assignments, you could change the broken pot to T Zero and be done with it that way.
    You will not be able to set the machine up to create an alarm condition when the broken pot is called, as this would have to be designed in the ladder, so this is about the best you can hope for.
    Sep 2019
    DARFIELD
    Thank you but my big problem is that I have 2 tool pots broken
    May 2016
    Then you can use the same system I listed above and turn your 2nd broken pot into tool 24. Then it's easy to remember to never program T0 or T24.
    Sep 2019
    DARFIELD
    Thank you, I solved!
    May 2016
    Good news!
    What was your solution?
  7. #7
    Sep 2019
    DARFIELD
    System-PMC Maintenece-Data-Imput-and I search my line for tool in spindle(you need to finde comment SPINDLE TOOL) and after that line I had tool number from 1-24. I take out all tools from magazine. After that I put in order in DATA from 1 to 24. After in MDI I called tool 6 and 8 to see if the pot is the same like in DATA and it was. In DATA for tool number that I had pot broken I put the biggest number allowed.After that I aranged DATA from 1-22.
  8. #8
    May 2016
    Well good. The diagnostic or data tables is a simple way to do it.
  9. #9
    Member cncmakers001's Avatar
    Jul 2011
    China
    Quote Originally Posted by vanova20 View Post
    It is really clever to do that.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  10. #10
    Dec 2009
    ROMANIA
    you did a great job!
