Need Help! CORTINI F120/25
Results 1 to 3 of 3
Thread: CORTINI F120/25
    Member andy86's Avatar
    Apr 2020
    Default CORTINI F120/25
    Hi guys, pleased to be on the forum i`m andy and i recently purchased a CORTINI F120/25 cnc lathe running on FANUC OT-C for a silly price.
    I wanted to use this machine for tapered fittings and spacer rings for the mining industry.
    last time i used a cnc machine i was in school so please forgive me if i1m quite rusted haha but the batteries were removed and all parameters were lost but with some careful tinkering i was able to reset the machine and get into the system but BUT on start up a screen pops up with 3 options
    1 RUN WITH I/O
    2 RUN
    3 RUN WITH PCM
    if i select RUN it indicates LADDER NOT EXIST
    if i select RUN WITH I/O the screen goes dark and it stays that way without changing
    if i select RUN WITH PCM i can access the parameters and alter them but not the diagnostics or to view the ladder.
    Please any help would be greatly appreciated.
    Dec 2009
    ROMANIA
    Default Re: CORTINI F120/25
    to view the ladder check if parameter 60 bit 2 is 1 for ladder display.
    Hello.
    I bought a Cortini F120 / 25 lathe without manual documentation. I found your post and thought maybe you have a manual for this machine.
    Hello.I bought a Cortini F120 / 25 lathe without manual documentation. I found your post and thought maybe you have a manual for this machine.
    Apr 2020
    Hi and yes I do have the manual documentation and the floppy disk as well, will take a while to scan all and send but can do that for you if needed
CORTINI F120/25
CORTINI F120/25
