Hi folks,
I need help regarding FANUC 32i-A Controller in which want to turn on option parameter. After 2006 Fanuc do not have option parameter in SRAM. They store option parameter in FROM. anyone did this work before, please help if anyone have procedure to turn on option Parameters.
thanks.
Hi
The option-parameters as earlier in SRAM area memories only you can not their see and change. The state these parameter you may see in image of the diagnostics 1110~1293. The attempt to change these parameters can destroy certificate.
You will have to call your machine tool builder to get the option turned on. They will have to contact Fanuc with a PO to get your option activated. Some machines Fanuc will do without the MTB involvment. You have to call Fanucand see what they are willing to do. Sorry no more back door.
thanks alot agering & drdos, for you great suggestions straight away no back door to done this job without involve Fanuc , i go with to call Fanuc for this work.
I need Fanuc 31i-M model A or 32i-M model A with helical option ,5 axis option 2 axis in PMC axis control (Standalone type) is anyone have i have urgently need of it.
