Please help me convert from .Lad file to PMC1,000 on Fanuc ladder iii
Hello everyone!
I have a problem with Fanuc Ladder software iii. I transferred a PMC1,000 file of the CNC Fanuc Lathe ( Oi-TF) to a ***. Lad file for editing in a sequence program of several M-code commands and signals.
But now I want to convert this ***. Lad file to the PMC1.000 file to reload into this CNC lathe. The problem is that I don't know how to transfer on Fanuc Ladder iii. So can you guide me to do that ?.
I would like to ask, if I reload this file after modifying it into the CNC machine, Will the machine lose data or the NC and PMC parameters of the machine be changed?
Thank you!
Re: Please help me convert from .Lad file to PMC1,000 on Fanuc ladder iii
1 whne uploading new ladder,will not loose any NC or PMC parameters
2. if you want to put it back,you need to export the file from menu and not save it.
good luck
